Real Gas Critical Properties for Averaged Mixture
Old   October 18, 2022, 20:19
Default Real Gas Critical Properties for Averaged Mixture
Braden Kerr
bfkerr is on a distinguished road
I am attempting to model a real gas using the Peng-Robinson EoS. I am aware that I need critical properties for such a model, and Fluent provides many already for pure components. I have a custom "pure" component that is really an average of mixture species. I dont have access to the full species breakdown, so I am unable to use the mixture equations. Since it is a custom material, I believe I will need to use RGP tables to generate the fluid property.
I have tabular data for the viscosity, conductivity and C_p based on pressure but have only found information for generation of RGP for CFX, not Fluent.
Is there a guide for generating RGP tables for Fluent and not CFX?
Thank you, bfkerr
bfkerr is offline   Reply With Quote
peng-robinson, real-gas, rgp
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
error message cuteapathy CFX 14 March 20, 2012 06:45
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Real Gas Mixture With Reactions Jake Cannon Main CFD Forum 0 January 16, 2007 11:46
