October 22, 2022, 14:01 |
Adsorption on a wall
Rep Power: 3 |
Dear All,
I would like to simulate a catalytic reaction (according to LH mechanism) in a rectangular channel, where only one wall of the channel is coated with the catalyst. As a first step, I have tried to focus on adsorption step. I have defined the following reaction: A(lq) + catalyst_s = A_s I have defined the catalyst_s as ''selected solid'' (within the mechanism), and A_s as '' selected site specie''. All of the species mentioned previously (catalyst_S and A_s) were defined as fluid. However, unfortunately this approach does not work. I have also tried to define both catalyst_s and A_s as site specie, however unfortunately I have not obtained appropriate results. Can you please give me some hints how should I define the catalyst_s? Thank you very much in advance! |
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall | JayDeeUU | OpenFOAM Pre-Processing | 16 | July 22, 2021 21:17 |
[snappyHexMesh] How to draw a 3D-Drawing for Meshing | Kahnbein.Kai | OpenFOAM Meshing & Mesh Conversion | 4 | June 15, 2021 12:16 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 05:37 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
