How to compare two fluent setup cases (.cas.h5) |
October 22, 2022, 18:39 |
Rick
Rep Power: 3 |
Hi Everyone,
I have two fluent cases that have the same setup (I think they have). I am getting completely different results using these cases. The cases comprise a two-way FSI simulation of aortic valve. I didn't have such problems working with CFX. Is there any way to compare the two cases to understand what their difference is? It would be great if we could open these case files in a text editor and then compare the two files together. I would appreciate any help that you can provide. Last edited by Rick; October 23, 2022 at 08:41. |
October 26, 2022, 08:05 |
Nawaf Alrajeh
Rep Power: 3 |
Try running both off of the same case.
Meaning, take the first case (.cas.h5) file, and replace the mesh with the other one. If everything is completely the same, it should work. You will get different results from the initialization, but the convergence (i.e physics) should be the same. |
October 26, 2022, 09:17 |
Gert-Jan
Rep Power: 27 |
You're hitting one of the disadvantages of Fluent over CFX.
October 26, 2022, 09:57 |
Rick
Rep Power: 3 |
Dear Nawaf,
This is a good idea. Thank you. The reason that I didn't go for this option is that when I want to do this, Fluent gives a warning message regarding the automatic mesh update feature. So, I thought by replacing the mesh some other settings would be modified as well. Dear Gert-Jan, Yep! It would be great if Fluent could add this feature. Last edited by Rick; October 26, 2022 at 16:38. |
October 27, 2022, 05:41 |
Liu Wenchao
Rep Power: 5 |
Try using fluent-TUI: file/write-settings. It allows writing your case settings and opening your setting in text editor. Hope it helps. |
October 27, 2022, 10:15 |
Rick
Rep Power: 3 |
Dear Liu,
Great. Thanks! I haven't worked with Fluent TUI so far. Does it refer to the "Console" tab at the bottom panel of the "Graphics"? |
October 27, 2022, 10:47 |
Liu Wenchao
Rep Power: 5 |
October 27, 2022, 15:29 |
Rick
Rep Power: 3 |
Perfect! It works!
Thank you! |
2xEPYC Setup, Fluent, 10M Poly Cells | Jeggi | Hardware | 2 | March 19, 2020 08:22 |
Fluent Solution to Fluent Setup | Tyson97 | FLUENT | 2 | January 22, 2020 04:43 |
Fluent Giving Different Results For Same Analysis Setup | Murwin12 | FLUENT | 0 | March 6, 2019 11:00 |
Setup for Fluent Flux Reports | Jallen13a | FLUENT | 7 | November 18, 2010 10:32 |
ALGOR? Its scripting language? Compare to Fluent? | Chris Bailey | Main CFD Forum | 2 | November 16, 2005 16:58 |
