October 31, 2022, 21:03 |
Calcualtion of Reynolds number in packed bed
xingangzheng
Rep Power: 16 |
I am simulating a heterogeneous reaction in a traveling grate (can be regarded as a packed bed), which infers the calculation of Reynolds number. Please help me to choose a correct formula from the followings (found from the literatures or Internet). Re1=Dp*U*rho/Mu Re2=Dp*U*rho/(Mu*porosity_bed) Re3=Dp*U*rho/(Mu*(1-porosity_bed)) Where Dp is the partical diameter, Mu is the Fluid viscosity, rho is fluid density. Question: 1. Which one is the most appropriate, 2. U use superfical velocity or physical velocity. Please help me. Thanks in advance |
November 2, 2022, 06:13 |
#2 | |
Nawaf Alrajeh
Rep Power: 3 |
You can use this equation: https://neutrium.net/fluid-flow/pack...ynolds-number/ which is Re3 for you, with U being superficial velocity. |
November 2, 2022, 08:12 |
#3 | |
xingangzheng
Rep Power: 16 |
Dear Nawaf_Ar,
Thank you very much.The link you gave is very useful. But unfortunately, it is still unclear where this formula originates from. Quote:
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
Boundary condition problem (Freestream) | KAYANO | OpenFOAM Running, Solving & CFD | 5 | June 1, 2021 05:57 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
