September 19, 2018, 16:48 |
Flow-induced vibration with dynamic mesh
Hi everyone!
I study flow-induced vibration (FIV) in cylinders and I want to simulate a moving cylinder subject to crossflow in ANSYS Fluent as a translational movement. Experimentally it is conducted with springs, having a natural frequency and a spring constant. I have already read some documents in internet, but I am still not able to do this kind of simulation. I have some questions: 1) Should I use 6 DOF option in Dynamic Mesh tab or it is better to use a UDF to represent the motion? If it works better with UDF, can you give me some ideas? 2) Could you please give a step-by-step tutorial related directly to this problem? 3) I have already tried some cases: 3.1 I defined the cylinder wall as a rigid body and the fluid as deforming; 3.2 With an inner-domain surrounding the cylinder, with both set as rigid body but the inner-domain with passive option enabled in 6 DOF and an outer-domain as deforming. But it hasn't worked yet. 4) Should I use overset mesh, or it isn't necessary? Thank you!! |
November 6, 2022, 16:23 |
Shakthi
Were you able to find the answers to your question? I am kind of in the exact situation now. Thanks |
velocity BC to provide flow rate relative to dynamic mesh motion | oschi | OpenFOAM Running, Solving & CFD | 1 | May 21, 2019 04:02 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
Dynamic mesh for a body in a flow (6DOF solver) | supermanks | FLUENT | 2 | January 10, 2016 21:16 |
dynamic mesh for flow induced vibration on circular cylinder.... | rishitosh | FLUENT | 1 | May 12, 2015 04:48 |
dynamic mesh for flow induced vibration on circular cylinder.... | rishitosh | Main CFD Forum | 1 | December 9, 2012 03:09 |
