November 9, 2022, 15:32 |
Porous material parameters for Filter
Hammad Naseem
Rep Power: 4 |
I am doing a simulation of a fan powered mask for which I need to define a filter material in the mask for simulation. I have defined the geometry of filter as fluid and then I am ticking the "Porous" block in cell zone conditions. There I can not understand how to determine what to write in "Direction 1-vector" and "Direction 2-vector" blocks. Can someone please explain this? The mask body I am using is in 3D |
cfd, filtering, fluent 14 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Porous Material with Liquid | Rock12 | FLUENT | 0 | September 11, 2017 06:41 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
