November 20, 2022, 15:21 |
Understanding Rayleigh-Taylor Simulation
Md Fahim Shahriar
Rep Power: 3 |
Hello everyone, I want to simulate Rayleigh-Taylor instability where I inject CO2 in water from the top interface and it moves through the water in a finger sort of formation (picture attached).
I created a geometry, where I selected the top-edge as mass flow inlet. I use an arbitrary mass flow kg/s. The other edges are set up as wall. When I run the simulation, the CO2 moves in a square shape (it fills up the whole surface gradually). I can't get the finger sort of movement pattern. I found this on the article, "To observe the non-linear behavior, i.e., the fingering behavior it was necessary to disturb the interface. Therefore in the numerical simulations, we start with a wavy perturbation on the top interface, i.e., c(x; z = 0;t = 0) = 1 + 0.01sin(2*pi*x/0.083) I don't have any experience on writing UDF. But seems like I need to change the inlet condition for time t=0, to a varied sinusoidal mass flow. How can I do that? Any sort of suggestion or help is greatly appreciated. (Side note: I can't find out how to provide concentration value of CO2 in mol/l. Instead I am doing everything as mass flow. Will that be any problem) |
November 20, 2022, 19:35 |
Micael
Rep Power: 18 |
Not so long ago (a couple of releases ago) you would have indeed written a UDF, but now you can achieve that very well with Named Expressions.
November 20, 2022, 19:49 |
Md Fahim Shahriar
Rep Power: 3 |
Thank you for replying Micael, can you kindly explain a little bit?
I am fairly new to Ansys Fluent and it would help me a lot if you give a detailed answer or guide me to some resources that can help. |
November 22, 2022, 11:26 |
Lucky
Rep Power: 66 |
Searched the manual or google "Named Expressions" in Fluent. There's a fair number of youtube videos as well.
Fanno Rayleigh flow in pipes | Dave | Main CFD Forum | 4 | August 1, 2021 04:52 |
Unable to get unsteady result for natural convection problem at critical Rayleigh no. | Monrah | OpenFOAM Running, Solving & CFD | 1 | November 3, 2019 08:47 |
How to Set Rayleigh Number In Fluent ? | Azeez1234 | FLUENT | 1 | February 15, 2018 12:21 |
Rayleigh Number | Thomas P. Abraham | Main CFD Forum | 7 | November 13, 2017 03:23 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 19:43 |
