Vasanth Kumar G
Rep Power: 5 ![]() |
Hi all,
I am trying to validate experimental result with simulation for pressure distribution for NACA wing model. I used the formula in https://turbmodels.larc.nasa.gov/lan...nter_4eqn.html to find the value of F_length, Re_c. Irrespective of my mesh, transition is predicted ahead of the experimental results-- meaning-- transition from numerical simulation is upstream and shorter in length compared to expeirmental work. I have used udf for different Re_th, Re_c and F_length but the result is same. My Re is nearly 0.1 million and I am using normal C-type mesh for the analysis. Any suggestions where I can get a course correction? |
ansys, boundary layer, gamma-re, transition, turbulence |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
General question about SST turbulence model | Richard Renaud | CFD Freelancers | 1 | December 19, 2015 04:13 |
Transition SST model - convergence problem with 2nd order discretization | xara | FLUENT | 4 | May 27, 2013 13:16 |
SST K- omega turbulence model | mb.pejvak | Main CFD Forum | 8 | September 16, 2011 08:52 |
