Fluid-Fluid domains heat transfer on intersecting surfaces
Old   February 24, 2023, 00:52
Default Fluid-Fluid domains heat transfer on intersecting surfaces
Jie-Ying Zhan
Jeremy167270 is on a distinguished road
Hello everyone, I'm new to CFD and I really need some help.
I am simulating a data center model. I want to set the boundary conditions of Heat Flux on the surface of the server. In order to simplify my problem, the attached file is a schematic diagram of my problem. How can I make the intersecting surface be heated and allow airflow to pass through at the same time?
Jeremy167270 is offline   Reply With Quote
Old   February 24, 2023, 13:23
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
You will want to define the interface as a Radiator. Use "Share Topology" in spaceclaim or DM and name the face in meshing something like "HeatedFace". In fluent, the face should be read as "Internal". Right click on the face and set it to radiator.
In the radiator dialogue box you can set either a heat transfer coefficient and temperature, or a heat flux as W/m^2. If you want to use the heat flux make sure you set the temperature to absolute zero. See attached picture for further details.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   March 2, 2023, 00:18
Default Thank you!
Jie-Ying Zhan
Thank you for your reply! This method does solve my problem. Thank you very much!
flow, fluid-fluid, heat flux
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Radiation interface hinca CFX 15 January 26, 2014 17:11
Solid / Fluid Heat Transfer Koranten FLUENT 3 March 19, 2011 07:21
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
