Clean Room Analysis
Old   November 4, 2006, 02:38
Default Clean Room Analysis
Madhusudan
Dear Sir,
The clean room analysis involves the effects of filters,Blower,volume control dampers,grills and ducts which has to be given as the fluid passage.Air flow pattern,pressure distribution across the rooms,temperature in that rooms are the expected outcome.If anyone suggest a package which deals only with the cleanroom analysis.
Old   March 28, 2023, 06:43
ganshhia
kekil1060 is on a distinguished road
There are various software packages available in the market that can be used for cleanroom analysis, depending on your specific needs and requirements. Some popular software packages include:
Fluent - This software is a computational fluid dynamics (CFD) package that can be used to model cleanroom environments. It can simulate air flow patterns, temperature distribution, and pressure differentials within a cleanroom.
Cleanroom Design Tool - This software is specifically designed for cleanroom design and analysis. It allows users to create 3D models of cleanroom environments and simulate air flow patterns, temperature distribution, and pressure differentials.
Comsol Multiphysics - This software is a multiphysics simulation package that can be used for cleanroom analysis. It allows users to simulate fluid flow, heat transfer, and particle transport, among other physical phenomena.
kekil1060 is offline   Reply With Quote
CFD for air flow analysis in a room bidalufias Main CFD Forum 1 May 12, 2011 19:11
Clean Room Analysis Madhusudan CFX 9 November 14, 2006 19:59
Module for clean room analysis Madhusudan Siemens 3 November 8, 2006 12:50
INLET object velocity Richard Phoenics 2 November 8, 2006 04:32
Clean Room Analysis Madhusudan FLUENT 0 November 4, 2006 00:39
