March 31, 2023, 05:03 |
URANS not converging - flow in channel
MC
Rep Power: 5 |
Dear all,
I would like to ask your opinion about a divergence problem I am encountering in Fluent. I am simulating the flow in a bifurcating channel (there is 1 inlet and 2 exit channels) by setting up inlet total pressure and outlet static pressures. The RANS is converging well, but when I start the URANS with the same model (realizable k-epsilon) it diverges after more than 5000 time steps, which I believe is quite weird. What do you think the problem might be? I am used to convergence issues which originate from the very first time steps (due to mesh and BCs) but this seems not to be the case. I was thinking that maybe there is a pressure wave propagating from the outlet to the inlet channel which causes solver issues, but I am not sure. What do you think about that? Thanks a lot |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
LES/RANS on Channel Flow Velocity Profile | hx293 | Main CFD Forum | 15 | August 29, 2017 11:34 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
flow depth in channel | mahdi1 | FLOW-3D | 5 | May 30, 2013 05:28 |
