April 9, 2023, 04:04 |
Combination of moving mesh and dynamic mesh
Rep Power: 6 |
I encountered a problem when I used the UDF “DEFINE_CG_MOTION” and “DEFINE_ZONE_MOTION”, the warning message below popped up during simulation: Warning: incompatible interaction between moving mesh and dynamic mesh model. Model and settings description: (1) As shown in Figure 1, the whole model consists of 3 fluid zone: fluid_1, fluid_2 and fluid_3, each zone is connected with interface. Fluid_2, fluid_3 and wall_bot_f1 are moving with a velocity v, now, I use “DEFINE_CG_MOTION” to control the motion of moving face, and “DEFINE_ZONE_MOTION” for fluid_2 and fluid_3. (2) Interface settings: Interface_1: wall_bot_f1 and wall_top_f2; Interface_2: wall_bot_f2 and wall_top_f3; (3) Dynamic mesh settings: Deforming: wall_f1 Rigid body: wall bot_f1; Rigid body: Interface_1; Rigid body: Interface_1-non-overlapping; Although the simulation can run normally, I am curious about this problem, what makes this happen? Does this problem influence the simulation result? How to solve it? I need your help and advice, thanks. Regards, |
dynamic mesh, fluent -udf, moving 3d mesh |
Mesh Disappering with Dynamic Mesh | FaroukH | FLUENT | 0 | February 23, 2021 18:26 |
How to define moving wall rotation axis origin in Dynamic mesh | touyet | FLUENT | 1 | July 4, 2016 09:24 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Explanation moving mesh, moving frame, or dynamic mesh | fbar | FLUENT | 1 | April 13, 2012 07:57 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
