Valve profile for an internal combustion engine
Like Tree1Likes
  • 1 Post By jemy.akvianto
Old   May 16, 2013, 10:20
Default Valve profile for an internal combustion engine
Omar
omar87st is on a distinguished road
I'm currently working on the Tutorial 12. Cold Flow Simulation Inside an SI Engine.
I don't understand the valve.prof file. when i open it with text editor i have this:
((ex-valve point 141 1)
(angle
1.119000e+02 1.120000e+02 1.140000e+02 1.160000e+02 1.180000e+02
1.200000e+02 1.220000e+02 1.240000e+02 1.260000e+02 1.280000e+02
1.300000e+02 1.320000e+02 1.340000e+02 1.360000e+02 1.380000e+02
1.400000e+02 1.420000e+02 1.440000e+02 1.460000e+02 1.480000e+02
1.500000e+02 1.520000e+02 1.540000e+02 1.560000e+02 1.580000e+02
1.600000e+02 1.620000e+02 1.640000e+02 1.660000e+02 1.680000e+02
1.700000e+02 1.720000e+02 1.740000e+02 1.760000e+02 1.780000e+02
1.800000e+02 1.820000e+02 1.840000e+02 1.860000e+02 1.880000e+02
1.900000e+02 1.920000e+02 1.940000e+02
If somebody can tell me what this file is for ? and what's the meaning of all the angles ?
Thanks.
Omar
omar87st is offline   Reply With Quote
Old   May 24, 2013, 08:23
Zacarias Carral
zcarral is on a distinguished road
Where did you find that tutorial? I am interested on that.
zcarral is offline   Reply With Quote
Old   May 24, 2013, 10:06
OJ
oj.bulmer will become famous soon enough
This is an input file for defining how valve lift varies with different crank angles.
Tutorial: http://cfd.iut.ac.ir/files/In_Cylinder.pdf
Files: http://www.mediafire.com/?6788sus7dcnd2
OJ
oj.bulmer is offline   Reply With Quote
Old   May 24, 2013, 11:03
jemy akvianto
jemy.akvianto is on a distinguished road
OJ
master, where i can get another tutorial about CFD? thanks
vinay kashyap likes this.
jemy.akvianto is offline   Reply With Quote
Old   May 24, 2013, 11:43
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
ansys customer service... you need your account number, otherwise just use google i'm sure you will find some in universities's website
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 25, 2013, 07:20
Omar
Thanks for your answer,
do you have any tutorial on the 3D internale combustion engine or adiabatic compression ? this will be realy helpfull for me.
Old   August 7, 2015, 10:19
Default Can you Please share me engine geometry as i failed in ciinstructing valve error Mess
Chotai Nikhil
nikhilchotai@gmil.com is on a distinguished road
I hope one of get success in cold flow simulation so request to share engine model because i am getting error message in valve sheat i tied a lot for same.
My email ID is
nikhilchotai@gmail.com
nikhilchotai@gmil.com is offline   Reply With Quote
Old   August 21, 2015, 09:58
Vijay Bodkhe
vijju is on a distinguished road
Sir, Can you give information about how valve.prof is created for any engines valve profile.I want to create valve lift profile of TV1 engine.So I can use it in Ansys Simulation of IC Engine.
Thanks in advance.
vijju is offline   Reply With Quote
Old   April 5, 2016, 20:59
Default Repost tutorail link
Ripusudan Agrawal
rsa10 is on a distinguished road
Can you please repost that tutorial link, the one you provided is not working. Thanks
rsa10 is offline   Reply With Quote
Old   November 17, 2017, 09:56
Default How can I patch my valve profile in Linux ansys
BIBU B
Phantomz is on a distinguished road
Linux OS ansys running
When I patching valve.prof. it shows ,not compatible for Linux so what change I need to do ?
Phantomz is offline   Reply With Quote
Old   December 6, 2018, 08:14
Default Downloading valve profile and geometry
  #11
AH
visitor is on a distinguished road
Have downloaded student version for fluent ic. Can't find where to download files referred to in title bar. Can anyone explain how where to go, thanks in advance.
Working this tutorial:-
Chapter 15: Tutorial: Solving a Cold Flow Simulation
Called for in this tutorial subsection: -
15.1. Preparation
1. Copy the files (demo_eng.x_t and lift.prof) to your working folder.
To access tutorials and their input files on the ANSYS Customer Portal, go to http://support.an-
sys.com/training.
2. Start Workbench.
visitor is offline   Reply With Quote
Old   January 11, 2019, 00:10
Kanaka Raju
kanaka raju is on a distinguished road
Thanks in advance.
we are doing an acadamic project on Ic engine cold flow analysis in cfd. How we write a valve lift profile?
kanaka raju is offline   Reply With Quote
Old   July 24, 2019, 12:44
AH
I have followed a tutorial on utube. Got pressure changes in cylinder, but couldn't see movement of piston wall. Is it a post processing issue?
Old   July 24, 2019, 12:47
AH
You could look at this example, it explains how such files are made.
Old   April 21, 2023, 05:35
Peace Akinlolu
Peaceakinlolu is on a distinguished road
OJ
Please, could you share the tutorial file again? I cannot access the pdf.
Peaceakinlolu is offline   Reply With Quote
engine, fluent, internal combustion, profile, valve
Fluent 2d 4 Valve SI Engine Cola1988 FLUENT 0 January 27, 2012 17:03
Proper BCs for internal fan serezhkin CFX 3 July 28, 2010 10:04
Can I simulate the internal combustion engine with OF? fuvictor OpenFOAM 0 October 27, 2009 21:40
Help: IC engine fan design Sigan Main CFD Forum 1 May 24, 2005 18:40
CFD simulation in Internal Combustion Engine Anne Main CFD Forum 17 May 5, 2005 05:06
