Chillers on Rooftop – Unrealistic Results – Question about Boundary Conditions
Old   May 5, 2023, 12:43
Default Chillers on Rooftop – Unrealistic Results – Question about Boundary Conditions
R P
Humancfd is on a distinguished road
Hello Fluent Experts,
Hope you are all doing great.
Would very much appreciate your thoughts and guidance on a technical challenge which I have been facing for quite some time.
A brief writeup on what is being performed in the simulation.
We have two chillers on a roof top. Each chiller has got 3 independent V circuits. We modeled two chillers as there is an uneven loading on the V circuits of the chillers (Not modeling the tubes and water flow inside. Taking into account only the air side pressure losses across the V coils)
Axial fans are modeled with the blade topography. Frame motion is assigned to the fan rotating domain, as well as to the blades of the fans. There is a mesh interface between rotating domains and stationary atmosphere region.
So, we assigned the loss coefficients to the porous coils, rpm to the rotating fan domains.
Mesh Orthogonal Quality is at 0.2
Have assigned pressure inlet on the sides (equal to 0) and pressure outlet at the top (equal to 0), trying to replicate stationary air at the far regions. We have data only for the RPM of the fans.
What is physically expected is due to the suction created by the rotating fans, atmosphere is sucked over the coils of the V, and pushed out in the upward direction to the atmosphere.
But that is not what we are seeing in the results.
First the velocity plot and the pressure plot do not look realistic. We see a high-pressure region till the far end of the outlet, which in turn is impacting the velocity field.
Would appreciate your guidance and thoughts as to what we are missing in the simulation model, like any corrections to be made w.r.t to the boundary conditions setup, etc.
Thanks a lot for your kind guidance and help
Humancfd is offline   Reply With Quote
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
