Error: CDR: invalid argument [1]: wrong type [not a pair];Error Object: #f
Like Tree15Likes
Old   September 1, 2009, 08:28
Default Error: CDR: invalid argument [1]: wrong type [not a pair];Error Object: #f
Perseu
Perseu is on a distinguished road
I have used the Fluent for simulation of wave generation in a tank (piston wave maker), but I have a problem when use a function "autosave". During the simulation, with many iterations (more 80.000), I saved the case and data through function autosave. However, when lack the electricity or when I cancel for a time and close the program for to begin again, occur the error:
Error Object: #f
Please, someone can help me?
Thanks
Perseu
Perseu is offline   Reply With Quote
Old   June 7, 2010, 02:39
mpa
mpa is on a distinguished road
Hi Perseu,
I have the same problem:
cdr: invalid argument [1]: wrong type [not a pair]
Error object: #f
what could it be? Have you found a solution?
thanks
mpa is offline   Reply With Quote
Old   June 26, 2010, 22:17
Default Error: CAR: invalid argument [1]: wrong type [not a pair]
王国斌
wangguobin14 is on a distinguished road
Send a message via ICQ to wangguobin14 Send a message via MSN to wangguobin14
hi ,
have you solved your problem,
what does it mean? how to smooth it?
thank you !
wangguobin@163.com for contact
wangguobin14 is offline   Reply With Quote
Old   June 29, 2010, 07:25
Default Error: CDR: invalid argument [1]: wrong type [not a pair] Error Object: #f
sandip chajjed
sanmysterio is on a distinguished road
hi,
I am also getting the same problem when i run my case in batch mode on cluster but it was running fine with gui
kindly help
sanmysterio is offline   Reply With Quote
Old   August 27, 2010, 05:00
yoossie is on a distinguished road
Nobody know how to solve this problem?
Because I'm only writing the events of a Dynamic Mesh, and (following a tutorial, but applied to my study) when I write my sliding interfaces it appears also this error.
I cannot understand, because, I have defined in the same way as the tutorial, I did it also in the same problem but with a different conditions (that they mustn't afect this) and it was no problem.
What can I do? Anyone knows?
Thanks for your replying
yoossie is offline   Reply With Quote
Old   September 17, 2010, 23:59
freeday's Avatar
freeday
freeday is on a distinguished road
So, do I....
Please help me...
freeday is offline   Reply With Quote
Old   September 3, 2011, 05:19
hcstudio
fossil is on a distinguished road
i have the same problem
fossil is offline   Reply With Quote
Old   September 3, 2011, 13:04
fox000002's Avatar
fox000002 is on a distinguished road
The error message indicates that there is an error in the scheme code.
A list value is needed, but a boolean value "#f" is fed.
You should check your case/data file, find the position and fix it.
fox000002 is offline   Reply With Quote
Old   December 30, 2011, 02:43
zayzan
zayzan is on a distinguished road
Find the position of what exactly? I don't get it!
Can you explain further please?
Thanks
zayzan is offline   Reply With Quote
Old   August 30, 2012, 16:03
Learner
raghu.tejaswi is on a distinguished road
Is this problem solved???
I had the same problem several times. I save the case (and data sometimes), close it and reopen it. IT works everytime.
Hope someone should try it out..
gjtmawa, 1988, 8cold8hot and 3 others like this.
raghu.tejaswi is offline   Reply With Quote
Old   August 30, 2012, 16:05
Learner
PS: or try remeshing (can be coarser or finer..), it should work
Old   January 10, 2013, 12:23
Default same error
  #12
bhushan patil
p.bhushan2727@gmail.com is on a distinguished road
dear frnd i am getting same error for my fluent problem any body knw ans plz tell me
p.bhushan2727@gmail.com is offline   Reply With Quote
Old   January 10, 2013, 13:01
Learner
Hi Bhushan,
did you try doing the things I mentioned in the above comment?
Honestly, it worked for me.
raghu
Old   January 11, 2013, 00:33
bhushan patil
hi raghu i have save case and data file done lots of time but i am getting same error i am doing Multiple Rotating Reference Frames problem tried remeshing but not getting .......... i have made interface and for my case is there any problem in that case
Old   January 11, 2013, 02:05
Learner
I do not exactly understand the quantum of your problem. The problem can be tricky when interfaces are involved. Make doubly sure your interfaces are perfect. WHen I got this exact error, I just saved this as a different filename in a diff folder and it worked everytime. Thats the reason I am commenting here.
If this does not work, probably you can describe your problem in detail and eithr me or someone else can help you. and pls check if the error you receive is exactly the same as mentioned in this post.
Old   January 11, 2013, 02:39
Default darreuis type wind turbine cfd
  #16
bhushan patil
DEAR raghu ,
i am doing my m.tech project in water turbine cfd with moving sate for that concern i have made my mesh as one paper and for that concern i have made one main rectangular domain in which one circular rotating domain and in that circle another 3 circular domain around the aerofoil shape baldes in that case whole circular domain with 3 inner circle is roatating with some angular velocity i have attaching some images of my mesh with this i have made interfaces for betn main domain-- outer domain , outer domain --3 inner circle ....and i am using for that concern Multiple Rotating Reference Frames for simulations ... its running but case and dat file recall this error ocuur.... and thanx for u r help ...& plz help me for that concern
Old   July 3, 2013, 11:15
Default Reset the model in workbench
  #17
Fan He
caitoc is on a distinguished road
Hi all,
I had this problem too during my fluent modelling in ansys workbench.
My solution is simple: reset the "Setup", open the fluent and now you should not encounter this error anymore
2626imran and ghorbali walid like this.
caitoc is offline   Reply With Quote
Old   July 8, 2013, 22:37
sajeesh
sajeesh is on a distinguished road
Hi all
I came across the same problem in VOF simulation when defining the Run calculation_create animation play back file..At that time just save the case and data file and reopen it..It will work fine...This is formed when reassigning more than a data to the same name..Eg contour plots of phases and pressure assign to same file sequence1..Assign each contour plot to each file and these problem wont arise...
This is what i am feeling
Thnx
Sajeesh
sajeesh is offline   Reply With Quote
Old   May 29, 2014, 07:50
Default Periodicity
  #19
Katja N.
Katja is on a distinguished road
Hi all,
I received the same error while trying to view periodic repeats of my geometry, so I guess it has something to do with wrongly defining the BCs?
Katja is offline   Reply With Quote
Old   August 26, 2014, 02:46
Tarl
Tank is on a distinguished road
I was receiving the same error message:
I solved this by deleting all my monitors. It also disappeared when I gave each monitor its own window.
So perhaps save your case and delete all your monitors to determine if this is the source of your problem?
Hope this helped!
Tobi, parco, soheil_r7 and 4 others like this.
Tank is offline   Reply With Quote
cdr, error, fluent, invalid argument, wrong type
Error: CAR: invalid argument [1]: wrong type [not a pair]??? Paulus Fluent UDF and Scheme Programming 7 August 30, 2013 06:28
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 05:59
