May 11, 2023, 08:28 |
Convergence
Rep Power: 4 |
My case of a rotaing flow inside a tank doesnt seem to converge. However all values I monitor like pressures and velocities become completely flat. This is both with standard as second order for pressure to solve. Can somebody advise? Last edited by Klavoir; May 12, 2023 at 07:53. |
May 11, 2023, 12:26 |
It sounds like you have it converged as good as it will for the mesh you have created. It is good that you have monitor points in addition to looking at the residuals. Have you conducted a mesh independence study? That would be the next step. Look at the flow field that you computed and make sure you resolve the regions that still have high residuals (you can look at contours of residuals in the Fluent results).
May 18, 2023, 20:12 |
#3 | |
USA
September 11, 2023, 21:07 |
#4 | |
September 21, 2023, 20:27 |
#5 | |
Since you mentioned this is a model of flow inside a tank, I'm wondering if you've checked whether the flow is becoming unsteady at any point, creating periodic vortices or turbulence that could prevent convergence. I recently ran into a similar situation when modeling air flow around an electric vehicle charging station. Small vortices were shedding off the charger and causing ev charger overheating. Adding some artificial dissipation helped damp out those unsteady effects. So if your model involves any bluff bodies or curved surfaces, that may be something to look into. Of course, it's hard to say for sure if that applies to your specific case without more details. But I hope reviewing boundary conditions, refining the mesh, and ruling out unsteady flow effects can ultimately help get your model to converge. Feel free to provide any other updates or info about your tank geometry, flow parameters, etc. Convergence issues are a rite of passage in CFD, but we can work through it! |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 18:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
