Electric conductivity as a funcion of electric resistance |
May 17, 2023, 16:40 |
anpi
Hi every body :
Hoping that everything is going well. i need urgent help please. -the electrical conductivity in my problem is not constant, it changes with electric resistance, and this electric resistance changes with temperature. the electric resistance in my problem is given by 𝑅=𝑅_0 (1+𝛼(𝑇−𝑇_0)) where T_0 is 20C and T is static temperature of the wire. and R_0 is 11Ohm. how can I write an expression to incorporate this resistance into the conductivity for aluminum in fluent. thanks thanks |
May 17, 2023, 19:15 |
Lucky
Rep Power: 66 |
Conductivity is resistance divided by the length and then multiplied by the cross-sectional area of the wire.
Since you are using electrical conductivity, you're clearly not using the basic Fluent but one of the additional modules. Do you have an option for polynomial in temperature for conductivity? Or anything? |
Treating Contact Resistance between two solids in openFoam (Thermal and electric) | meshingpumpkins | OpenFOAM Running, Solving & CFD | 1 | January 13, 2023 06:56 |
Conductivity as a vector value | Nurzhan | CFX | 19 | June 19, 2021 05:30 |
[Other] Thermal calculation of the vacuum electric resistance furnace | RoPr | OpenFOAM Meshing & Mesh Conversion | 0 | May 13, 2019 03:21 |
IAPWS water properties + orthotropic thermal conductivity | Chander | CFX | 1 | February 29, 2012 17:26 |
electric resistance energy consumption | nilay | FLUENT | 0 | October 10, 2008 10:46 |
