Moving frame and Porous zone
Old   May 19, 2023, 04:44
Default Moving frame and Porous zone
Dmitry
Legat is on a distinguished road
Hello!
I need to calculate the heating of a moving layer of ore particles, which located on a moving grate. Previously i calculate a similar task, but i heating solid body. I used a moving frame option in a cell zone properties. The results were comparable with the results of the experiment. In a new task i want to represet the ore layer as a porous zone and use a moving frame option. But moving frame option doesnt affect the heating process. Temperature field is equally with enabled and disabled moving frame option. In the user and theory guide, I did not find any obvious incompatibility between Cell Zone parameters, such as Moving frame and Porous zone. There are actually two questions: this bundle should work and I messed up something, or maybe there is another way to calculate the heating of a moving layer of particles?
Legat is offline   Reply With Quote
Porous zone undergoing motion: translation/rotation mechkween OpenFOAM 0 November 28, 2022 08:53
porous media in rotating zone roshanak.rabiee878 OpenFOAM Programming & Development 1 May 16, 2020 08:16
TUI Command for Cell Zone Condition? artkingjw FLUENT 2 February 25, 2018 07:38
Stage Frame Change + Porous Domain CFX_Beginner CFX 10 August 10, 2015 04:28
Moving Reference Frame with Porous media guido_adriaensen OpenFOAM 3 November 25, 2009 05:09
