Disappearance of low Re damping option from Fluent 2022 R2 |
May 30, 2023, 11:35 |
Pritesh Ramya
Hello!
I have been trying to simulate flow past a cylinder with Re = 26700 using three turbulence models, namely, k-w SST, k-e realizable with enhanced wall treatment (henceforth referred to as KEEWT) and Spalart-Allmaras. Now in the past versions of Fluent, I have seen that k-w SST and Spalart-Allmaras had Low-Re correction and Low Re damping options respectively (I assume they serve the same purpose). Given that my maximum y+ is approximately equal to 0.6, I wanted to switch this functionality on for my k-w SST and Spalart-Allmaras runs. I was able to do it for k-w SST but I could not find the option for Spalart-Allmaras in the version of Fluent I am using, i.e., 2022 R2. I have gone through the user guide and there is no mention of the absence of this feature. Does it mean that they have removed the option, given that it is a low-Re turbulence model? Thank you. |
June 2, 2023, 05:14 |
Pritesh Ramya
Nevermind, the engineers at ANSYS helped me resolve the issue. Thank you!
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
