Porous media pressure drop not agreeing with the experimental values
Like Tree3Likes
  • 1 Post By MKuhn
  • 2 Post By Jmaes
Old   June 3, 2023, 16:32
Default Porous media pressure drop not agreeing with the experimental values
James Ranawadia
Jmaes is on a distinguished road
Hello everyone,
I have the experimental pressure drop data through a porous media and I trying to simulate it in fluent. My geometry is in the attached image. The brown part is the porous zone and the entire thing would be vertical. I found the porous media parameters using data and applied it but the pressure drop I am getting is way lower than that in experiment. Where could I be going wrong?
I tried to simulate the pressure drop in just the inlet part until a few millimeters after the channels end and tried to replace is with just one section of equivalent diameter and a porous zone but the pressure drop in this case was higher.
I've been trying to do this for the past two days but I am getting no results. Please help me. You can find the parameters I used in the attachments.
Jmaes is offline   Reply With Quote
Old   June 8, 2023, 07:54
Moritz Kuhn
MKuhn is on a distinguished road
What are your material properties? Calculating with a constant density could be a reason.
MKuhn is offline   Reply With Quote
Old   June 8, 2023, 08:04
James Ranawadia
The fluid is water and I don't suppose I need to specify the porous medium material, do I?
Old   June 8, 2023, 08:13
Moritz Kuhn
No, I don't think so either. Sorry porous media is not my field.
Jmaes likes this.
Old   June 8, 2023, 08:45
James Ranawadia
Thanks anyway
MKuhn and semj like this.
Old   June 8, 2023, 10:04
James Ranawadia
Hello semj,
Thanks for the insight. Is there a way to choose a specific equation? I always thought that fluent does this on it's own.
I am aware that the flow through a packed bed is modelled using the Ergun's equation and you can find the viscous resistance and inertial resistance parameters in one of the images I attached in my original question.
Furthermore, you can find the geometry in one of the images as well. What you see is the fluid volume extracted using SpaceClaim. The porous zone is activated carbon particles of average diameter of 0.7 mm and the diameter of the middle sector is 31.92 mm. The length of the porous zone is 3cm. The setup is vertical, in that, the porous media would be at the bottom though It doesn't have to be at the bottom, it can be half way through the pipe.
I think the reason the experimental data doesn't match with the simulated data could be due to the reduced velocity by the time the water reaches the porous media. In the actual experiment, the water starts to fill up in the middle sector and acts pretty much like a bottle with a hole at the bottom. However, I do not have any equipment that to measure the velocity of water right before it reaches the porous zone
porous media parameters, porous medium, pressure drop
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 05:40
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
FLUENT + porous media and direction angle zog FLUENT 2 August 11, 2019 09:47
lower pressure drop compared to experimental value in Two phase flow calculations. Ash Kot Fluent Multiphase 0 May 16, 2017 16:29
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
