October 9, 2013, 07:43 |
electrolysis of water
CHHATTISHGARH
Rep Power: 12 |
hellow everybody:
My name is Luke. I am trying to simulate the chemical reation which is about the multiphase flow (two phase). I consider the liquid-water in a electrolyzer and there are two electrodes in it. I want to electrolysis the liquid-water and produce the H2 at the surface of cathode and the O2 at the surface of anode. Beside, the mass of the H2O(consumpted), H2(generated) and O2(generated)must to be shown or calculated in my problem. The simple chemical reaction is below. H2O(liquid)---->H2(gas) + O2(gas) This problem is involved with the multiphase and the species transport. Which multiphase model should I choose? And how can I see the phenomenon of the species transport? And how can I calculate the amount of the H2 or O2 which is generated by the chemical reation? Please help me. Thank you~ |
October 10, 2013, 02:48 |
A-A Azarafza
Rep Power: 14 |
Hi there!
What kind of Electrolyser are you going to model? Is it a PEM, SOFC or other kinds?
Regard yours |
October 10, 2013, 09:14 |
CHHATTISHGARH
Rep Power: 12 |
Dry Cell HHO generator.
October 10, 2013, 18:57 |
A-A Azarafza
Rep Power: 14 |
I'm working on PEM electrolyser but never heard anything of that.
Regard yours |
October 10, 2013, 23:43 |
CHHATTISHGARH
Rep Power: 12 |
have you checked in google? it is very simple two electrode in KOH electrolyte solution
February 16, 2015, 12:07 |
electrolyse of water with PEM electrolyser
Hamed Moeini
Rep Power: 12 |
Hi
I need some information about simulation of water electrolyse process. please give me any information about this subject. thanks. |
August 10, 2019, 07:57 |
Andhra Pradesh
Hi..I need help in PEM Water electrolysis.
I keep getting this error in 18.1 version, "Fatal signal received (Segmentation Fault)". Resetting the setup tab didn't help though. And in the 2019R2 student version, the solver shuts down abruptly after clicking on 'run calculations' and I'm not even able to note the error. I'm not able to narrow down to what I'm missing. It's for my M.Tech project and I'm supposed to validate the experimental results. It's a single cell, The channel is parallel flow, GDL is present only on the cathode side. Membrane used is Nafion 117. Can someone help me please? |
April 18, 2020, 11:43 |
Rep Power: 6 |
hello.
i need help to simulate pem water electrolysis can you help me? send tutorial about it . i use fluent also i have problem with 2d mesh thanks in advance my email: alamir3182020@gmail.com |
April 19, 2020, 21:59 |
#9 | |
Rep Power: 6 |
June 16, 2023, 03:28 |
PEM water electrolyzer two-fluid model
#10 |
Muhammad Faizan
Rep Power: 7 |
Hi there!! I need some help in eulerian 2 fluid model simulation which I am doing for my PEM water electrolyzer. The thing is I am using UDF to define my source and sink term. At the anode, I am defining the boundary condition as only liquid inlet flow and I defined the mass source term for the oxygen (gas phase). While doing so, the gas phase volume fraction immediately reaches 1 making the liquid phase volume fraction 0 resulting in divergence. I need some idea on how the volume fraction is being calculated?
June 22, 2023, 11:22 |
#11 | |
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
Rep Power: 16 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
Separation phenomenon of water, droplet and air | Raymond | CFX | 0 | July 9, 2004 22:59 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
