Applying Boundary conditions for non-equilibrium thermal model in porous zone
Old   July 1, 2023, 00:17
Post Applying Boundary conditions for non-equilibrium thermal model in porous zone
Mohammad
Selawe97 is on a distinguished road
Hi
I have a simple 2d square domain with heat flux at the bottom, when I activate the non-equilibrium thermal model in porose media in fluent, it creates a new solid zone coincides with the fluid zone, and as a result of that it creates new walls at the boundaries of the domain, for example, I will be having two walls at the bottom, one for fluid and a new one for the solid (porous zone) which mean two walls at the bottom boundary, the question is where should I apply heat flux, or in other words how I should apply heat flux at the bottom so the total heat flux be 4000 w/m^-2. to a fluid wall or solid porous wall or do I still need to do another step?
Thanks for helping
Selawe97 is online now   Reply With Quote
interface, ltne, non-equilibrium model, porous zone, wall boundary conditions
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
