DPM injection number tracked = 0
Old   April 27, 2023, 07:56
Default DPM injection number tracked = 0
zhubin
zhu-jsut is on a distinguished road
Hello, everyone
I am currently working on unsteady particle track with a transient flow. The nickel particles (density = 8900 kg/m3) can not be tracked, and the console shows:
Advancing DPM injections....
number tracked = 0, escpaed = 0....
It's a 2D axisymmetric model with a minimum mesh size of 0.002m, 0.001s fixed time step. The particles are injected from the inlet, surface type, and the parameters were set as
other parameters by default.
So, if anyone has ever encountered this problem, please tell me the possible reasons.
zhu-jsut is offline   Reply With Quote
Old   July 25, 2023, 17:18
erphan
erphan is on a distinguished road
Hi Zhu
maybe the problem is your particles are NOT located in your domain. usually, I faced to this error while using DPM, when my particles located out of the domain.
erphan is offline   Reply With Quote
dpm, number tracked
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
[Other] Equal decomposition of cylindrical fluid domain Sean95 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2019 03:34
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Controlling Number of particles in Surface Injection (DPM) santoshroopak FLUENT 7 August 3, 2013 12:17
