Is it possible to give each band different emissivity in Fluent Radiation?
Like Tree1Likes
  • 1 Post By jswony11
Old   January 30, 2020, 19:40
Default Is it possible to give each band different emissivity in Fluent Radiation?
jswony11
jswony11 is on a distinguished road
Hi, I'm trying to model radiation with box (1 bottom + 4 side is aluminum, upper case is material A)'
Geometry is simple : Cube with 6 side (1 bottom / 4 side / 1 top)
1. When you use radiation model - Discrete radiation and Solar Ray Tracing in Solar Load, you can change spectral fraction (V/V+IR)
What is difference between visible and infrared in Fluent radiation?
I know that visible is nearly 300nm~700nm and infrared is 700nm~, but does ANSYS Fluent separate visible and infrared region with wavelength range as I mentioned above? Or do they just separate them by energy percetage regardless of wavelength?
ex) Direct Solar Irradiation = 1000W/m^2
Spectral Fraction = 0.5
-> Visible 50% (=500W/m^2) + Infrared 50% (=500W/m^2)
2. How can I give different transmissivity with more than 3 wavelength region?
I used Discrete Ordinates (DO) Model since it is the only model with 'semi-transparent' and 'non-gray' mode.
I want to give material A (semi-transparent) transmissivity like this:
ex) t=0.9 in 300~700nm
t= 0.1 in 700~8000nm (0.7 ~ 8 micro-meter)
t=0.9 in 8000nm~13000nm (8 ~ 13 micro-meter)
(t is transmissivity)
But when I change BC type of upper case (material A) from opaque to semi-transparent in boundary condition - radiation tab, there is only transmissivity (and absorptivity on left side) of Direct Visible and Direct IR.
I made three band (300~700 / 700~8000 / 8000~13000) in Model - Radiation - Number of Bands, but I could only change Direct / Diffuse Irradiation and Diffuse Fraction of each band, not transmissivity or emissivity of each band.
Is it possible to give each band different emissivity?
I'll be glad if someone could give me some advice.
Светлана likes this.
jswony11 is offline   Reply With Quote
Old   January 31, 2020, 04:13
Default Three inputs
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Fluent expects three values, one for IR, one for visible and other for shading. So, you have 0.9 for first value, 0.1 for second, and 0.9 for rest.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   September 22, 2021, 01:27
kuzma169 is on a distinguished road
It can be done by set just in material mixture, or air of you don't use species.
Dear swony11 send me polinomial or other expression for scattering and rest term for the bands1-3 0.3-0.7microm 0.7-8 and 8-13 as you wrote early. It's very need to me.
kuzma169 is offline   Reply With Quote
Old   July 25, 2023, 05:03
marwane cherkaoui
marwane cherkaoui is on a distinguished road
hello, I think you first need to choose the 3 bands in the radiation section (DO method), then you choose gray-band for the absorption coefficient in the materials section and finally semi-transparent in the boundary conditions for each wall. You will find the variation in absorption and transmission for each band (below in the boundary conditions in the radiation section). I hope this solves your problem
marwane cherkaoui is offline   Reply With Quote
radiation
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Radiation Modeling Chris89 CFX 20 August 14, 2014 07:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Radiation - Emissivity crevoise STAR-CCM+ 3 December 20, 2013 11:42
Radiation in Fluent Arpit FLUENT 12 June 18, 2007 12:57
