PyFluent postproc - assign report value to a float variable
Old   August 15, 2023, 08:19
Default PyFluent postproc - assign report value to a float variable
Zalan Zsigmond
Zalan is on a distinguished road
Hi All,
I'm new to Ansys PyFluent and I'd like to have an surface-average temperature report value assigned to a numerical (float) variable in PyFluent.
Doing this TUI command within Fluent Console:
/report/surface-integrals/mass-weighted-avg/ycut_1 temperature no
Gave the following output:
Mass-Weighted Average Static Temperature [K]
ycut_1 345.40113
When I run the PyFluent-equivalent command of the above code in Jupyter Notebook, some strange 'False' boolean is given as output:
Commands:
t_bulk = solver.results.report.surface_integrals(report_typ e = "area-weighted-avg", surface_id = ["ycut_1"], cell_report = "temperature", write_to_file = False)
print(t_bulk)
Result:
Area-Weighted Average
ycut_1 342.32108
False
Assigning this command to a variable results in a 'bool' type variable but this is weird as it seems a string to me:
Command:
type(t_bulk)
Output:
bool
My question is: do you know any trick on how to get just the numerical value of this report (in above example, 342.32108)?
Many thanks in advance.
Zalan is offline   Reply With Quote
Old   August 28, 2023, 11:14
wuhaibin
HB833 is on a distinguished road
I have encountered similar issues, but what I want to store the text, and I use: message_ Session. tui. mesh. manage. list(),the i get all the information about the mesh of all fluid. I want to save it as a string type into a variable, but I failed. I am unable to save some values and text in pyfluent. Have you made any progress on this issue recently? Can you help me?
HB833 is offline   Reply With Quote
Old   September 4, 2023, 15:53
Default Same question
Quique Dios
quiquedios is on a distinguished road
Has anyone figured this out already? I'm finding the same issue
Originally Posted by Zalan View Post
Hi All,
ycut_1 345.40113
Commands:
print(t_bulk)
Result:
ycut_1 342.32108
False
Command:
type(t_bulk)
Output:
bool
quiquedios is offline   Reply With Quote
pyfluent, pyfluent core, reporting, tui
generating report definition shows Unbound variable Shamoon Jamshed FLUENT 7 September 21, 2021 02:40
Report Output Filename - variable Jiricbeng CFX 0 August 15, 2014 07:44
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 14:59
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
