March 12, 2004, 07:20 |
Gray Radiation
Can anyone give me a brief description of what gray radiation is and when should the discrete ordinates radiation model activate the non-gray model. And is there a guideline for the number of bands that should be used if the gray modelling is necessary? Thanx Newbie |
December 20, 2012, 07:15 |
Odakkattuvalasu
Rep Power: 14 |
Hi Community,
Requesting someone to shed light on a question that was previously asked. I am starting to learn radiation models in Fluent. While reading the user manual on Setting up of P-1 radiation model I came across the terms, "Non-gray model" and "Gray Model". If I increase the number of bands to any value greater than 0, it becomes a non-gray model which is expensive in terms of computation time. Questions are: What is the difference between non-gray and gray models OR Under what conditions would you go for a non-gray or a gray model? How do you determine is a given problem can be considered as a gray radiation problem without losing significant accuracy. Thanking you for sharing any thoughts or information, Sincerely, RSSLNT |
December 22, 2012, 02:39 |
#3 | ||
Lucky
Rep Power: 66 |
The gray model offers a huge simplification to real problems. The gray model should always be used first wherever possible. If more accurate solutions are desired, then it may be appropriate to use a non-gray model. Quote:
Some care should be exercised, because many media being considered nowadays have narrow emission bands in their intended operating conditions but very broadband emission at "normal conditions". |
December 31, 2012, 06:33 |
Odakkattuvalasu
Rep Power: 14 |
Thank you very much. Appreciate your interest in clarifying the doubt.
March 23, 2016, 06:18 |
Bhushan
I am dealing with same radiation problem as yours. While doing radiation modelling by D.O. method. Can you tell me how should I proceed??? Thanks and regards. |
March 23, 2016, 10:53 |
Suraji
Rep Power: 10 |
Some modelling to anlyze radiation case in fluent, how is better modelling to analyze furnace radiation?
May 15, 2020, 03:45 |
radiation model
#7 | |
noorlina
Rep Power: 6 |
Dear lucy tan, when you said about absoprtivity, is there refering to absoprtion of coeffiecient air? because when used the radiation model, i found the material properties of air need to insert in some value.
September 18, 2023, 00:42 |
#8 | |
Canh Doan
Rep Power: 2 |
I am modeling a 1070 nm laser beam, that focuses on a high-pressure Xenon gas volume. At a high enough temperature, the Xenon gas will absorb the laser radiation and generate temperature at the focusing point. I found that the DO model can set up the wavelength with non-gray model. I am curious that could I setup a laser beam in the Ansys Fluent? Please see my attached photo. |
Non gray model in DO radiation model in Fluent | novice | FLUENT | 2 | January 19, 2015 14:26 |
Multiphase radiation in CFX | Luk_Fiz | CFX | 5 | March 17, 2009 03:51 |
BC for Gray S2S Radiation in ccm+ | Kalle | Siemens | 1 | January 29, 2009 15:04 |
Radiation: definitions | visatron | CFX | 7 | January 8, 2004 15:25 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
