Setup issue in fluent
Old   October 12, 2023, 14:56
Exclamation Setup issue in fluent
Rana abdo
Rana abdo is on a distinguished road
I have got some rough surfaces data that i have attached on a ship these surfaces differ from each other one has low density of roughness and the other is very rough. After attaching these surfaces on the ship the ship has become with a rough geometry but the difference of these surfaces are in microns. The problem is when i use fluent to calculate the drag on the ship having these two rough surfaces the values are the same although the roughness have changed.
What could be the problem
Note : when i use different y+ value the drag changes so how can i set the y+ value for the ship surface.
Also there is new cell domain that appears that os called fluid other than the orignal one and a wall shadow so what is the reason behind this.
I couldnt split the domain in space claim the rough ship surface causes error in the geometry
Rana abdo is offline   Reply With Quote
ansys, fluent 19.1, roughness, space claim, y+ values fluent
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 9, 2022 23:58
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
Fluent Giving Different Results For Same Analysis Setup Murwin12 FLUENT 0 March 6, 2019 11:00
fluent issue in windows hpc pack 2012 r2 mosesHPC FLUENT 17 January 12, 2019 15:01
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
