How to make my simulation converge?
Like Tree2Likes
  • 1 Post By LoGaL
  • 1 Post By AlexanderZ
Old   November 21, 2023, 05:23
Question How to make my simulation converge?
Hanako is on a distinguished road
Hello everyone,
I'm a master's student and relatively new to Ansys Fluent. Since September, I have been learning how to use it from scratch by myself.
I'm writing this post because I'm struggling to let my simulation for an abrupt expansion pipe converge.
The geometry of my abrupt expansion pipe is like this:
Mesh qualities:
- Minimum Orthogonal Quality: 0.16
- Maximum skewness: 0.39
(According to the manual, these qualities seem to be okay, though it's not that good.)
The setup in Fluent that I did is the following:
Solver setting in General:
- Type: Pressure-Based
- Velocity Formulation: Absolute
- Time: Steady
Since the flow is laminar(Re for the thin pipe = 2000, Re for the thick pipe = 666), I choose the Laminar model.
Boundary conditions:
- Inlet velocity = 0.172 m/s
- Outlet pressure: Gauge pressure = 0 Pa
When I set smaller inlet velocity (0.001 m/s, 0.003 m/s, 0.005 m/s, 0.011 m/s, 0.021 m/s, 0.043 m/s), the simulation successfully converged. However, with a larger inlet velocity like this time (0.172 m/s), the simulation no longer converges...
I tried the following solutions, but none worked well:
- Increase the number of iterations
- Change fluid time scale
- Change relaxation factors
I have been trying my best to think about possible solutions by myself, but unfortunately, I have not succeeded. I would appreciate it if some of you could give me possible suggestions.
Hanako is offline   Reply With Quote
Old   November 21, 2023, 15:11
Lorenzo Galieti
LoGaL is on a distinguished road
Do you have flow separation when the pipe area increases?
Hanako likes this.
LoGaL is offline   Reply With Quote
Old   November 21, 2023, 21:41
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
get converged solution for 0.043 case
don't reinitialize, increase inlet speed and run simulation again
increase inlet speed gradually
Hanako likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 27, 2023, 11:18
Hi LoGal,
Some eddies were observed.
I did meshing again and then my simulation successfully converged.
Anyway, I really appreciate that you kindly gave me a prompt reply. Thank you for your help.
Best regards,
Hanako
Old   November 27, 2023, 11:23
Hi AlexanderZ,
Thank you very much for your suggestion.
After re-meshing, my simulation successfully converged.
But I'll try your suggestion later as well for my learning.
Best regards,
Hanako
converge case setup, converge error, laminar, laminar flow in pipe
somaFoam - And plasma goes weee Destouches OpenFOAM Running, Solving & CFD 9 March 14, 2024 18:40
[blastFoam] BlastFoam Question alimea OpenFOAM Community Contributions 17 January 28, 2023 10:50
Help to make LES simulation faster Pj. OpenFOAM Running, Solving & CFD 14 December 10, 2019 04:13
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 12:39
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
