NACA Wing CFD Repeatability Problem
Old   January 22, 2024, 10:49
Default NACA Wing CFD Repeatability Problem
BY
NumericalGuy is on a distinguished road
Hi everyone,
I have a geometry of gliding vehicle which has a cylindrical body and large wings. I also have a mesh and results which are formed by someone else. I need to generate same results with geometry I have. I tried to generate similar surface mesh and I generated volume mesh with the same settings. Actually, my mesh quality is a little bit higher than old work. I also use same turbulence model (Spalart-Allmaras). And all other major settings are similar. I get solutions with different angle of attacks.
The problem is although I can generate similar results for angle of attacks b/w -8 to 6, beyond this range I cannot get similar results (Mach 0.5). The reason is flow separation occurs at wings beyond this range; however, flow separation does not exist previous solutions. I tried to do everything similar mesh, turbulence model, pressure based solver, ideal gas assumption etc. But I don't know what did I do differently from previous work which changes flow behavior.
Do you have any idea that can lead this important difference?
NumericalGuy is offline   Reply With Quote
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 07:33
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 16:07
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 00:30
3D Naca wing divergence Bollonga FLUENT 27 March 10, 2013 14:08
CFD of 3D Wing Tip Blowing NLao Main CFD Forum 1 March 1, 2012 01:44
