Rep Power: 3 ![]() |
Hi everyone,
I'm currently working on modeling User-defined wall function for ANSYS fluent. I'm using standard k-epsilon model for my simulation, and fluid domain has a width of 3H, a height of 2H, and a length of 6H, where H is a variable. The domain is bounded by lower and upper smooth walls, with a Friction Reynolds number(Re_tau) of 180 and a Bulk Reynolds number(Re_b) of 5600. Now, I'm confused about y+, y* for meshing and how wall function works. Here's my current understanding: 1) If y+ <11.225, u+ = y+ is applied; otherwise, u+ = 1/kappa*ln(Ey+) is used 2) It's recommended to avoid putting cells in the buffer layer, i.e. 5<y+<30. 3) According to the Ansys Fluent theory guide, Fluent uses y* and U* rather than y+ and U+ for Standard wall functions. The lower limit always lies in the order of y*~15. 4) In most case, y+~y* anyway. My question is, If we set lower limit of y*~15, as y+~y*, then y+ is also ~15. It means cells are on the buffer layer. So, to meet both y+ and y* conditions, should I make the first cell's y+ and y* values at least 30, or just need to satisfy y* ~ 15? If it's necessary to meet both conditions, it seems that the cells are too large from my perspective. I have around 6 cells between the upper and lower walls. Also if it's wrong, y*~15 gives too large cells either, around 10 between walls. I'd appreciate any insights or guidance on this matter. Thanks. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
