How does Ansys Fluent calculate the total heat flux on a wall surface? |
Melanie
Rep Power: 0 ![]() |
I'm trying to unterstand how Ansys Fluent calculates the heat flux / total heat ransfer rate on a wall surface. I'm analysing an external flow (air) around a wall with constant temperature as the boundary condition. My target value is the heat flux that the wall transmits to the environment. My wall is just an enclosure around void and no solid body. In the theory guide (https://ansyshelp.ansys.com/account/...ransfer%20rate) I found the sentence "The conduction heat transfer on a constant-temperature wall face would be the product of the thermal conductivity with the dot product of the area projection and the temperature gradient." Is this also applicable for external fluid flow or only for conduction in a solid body? When I got it right, the definition of a wall boundary condition is that there can't exist any convective flows. So I assume that Ansys Fluent does the exact thing statet in the theory guide, but I'm not quite sure and would like to hear your thoughts. 🙂 Thanks for any help. Kind regards, Melanie |
external flow, heat transfer, surface temperature, wall boundary condition |
Unrealistic Heat Transfer Coefficient and Total Surface Heat Flux values | war_mad | FLUENT | 0 | November 30, 2023 08:16 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
Measure of Heat Flux on a surface | MathieuCrslt | FLUENT | 0 | October 10, 2018 05:58 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
