February 10, 2024, 01:03 |
Ansys Fluent v232 crash on starting
Omar Zaki
Rep Power: 2 |
I am trying to start Fluent 2023 R2 Meshing with 36 cores. Processor is AMD Ryzen Threadripper PRO 7995WX.
I get the following error: Code:
Welcome to ANSYS Fluent 2023 R2 Copyright 1987-2023 ANSYS, Inc. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: Aug 18 2023 08:31:10 EDT Build Id: 10213 Connected License Server List: ###### -------------------------------------------------------------- This is an academic version of ANSYS FLUENT. Usage of this product license is limited to the terms and conditions specified in your ANSYS license form, additional terms section. -------------------------------------------------------------- Host spawning Node 0 on machine "OmarZaki" (win64). [mpiexec@OmarZaki] wmain (mpiexec.c:2165): assert (pg->intel.exitcodes != NULL) failed [mpiexec@OmarZaki] HYD_sock_write (..\windows\src\hydra_sock.c:387): write error (errno = 34) Code:
-mpi=openmpi Code:
-mpi=intel2018 I tried Ansys Fluent 2023 R1, and it is working normally. I also tried launching Ansys Fluent 2023 R2 with 1 core, and it is working normally too; The output is the following: Code:
Welcome to ANSYS Fluent 2023 R2 Copyright 1987-2023 ANSYS, Inc. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: May 29 2023 07:58:23 EDT Build Id: 10212 Connected License Server List: ###### -------------------------------------------------------------- This is an academic version of ANSYS FLUENT. Usage of this product license is limited to the terms and conditions specified in your ANSYS license form, additional terms section. -------------------------------------------------------------- Host spawning Node 0 on machine "OmarZaki" (win64). ------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ------------------------------------------------------------------------------- n0 OmarZaki 1/96 Windows-x64 44072 AMD Ryzen host OmarZaki Windows-x64 44500 AMD Ryzen MPI Option Selected: intel ------------------------------------------------------------------------------- Cleanup script file is #### What would be the issue? |
February 10, 2024, 17:20 |
Lucky
Rep Power: 66 |
Make sure you have the prereqs installed.
February 12, 2024, 15:36 |
Omar Zaki
Rep Power: 2 |
I made sure all prerequisites were installed. Also, I tried Ansys 2024 R1 and it gives me the same error.
March 25, 2024, 20:26 |
Artem
Rep Power: 2 |
I'm encountering the same issue right now. I have a dual CPU EPYC build and Fluent 2023R2 and 2024R1 crashes with the same issue.
The only version that is actually loading is 2023R1. Please let me know if you find a solution. Thanks! |
March 28, 2024, 12:10 |
Omar Zaki
Rep Power: 2 |
I have not found a solution yet. I am trying to communicate with Ansys Help Platform now to find a solution, but they are extremely slow in their replies.
March 28, 2024, 12:13 |
Artem
Rep Power: 2 |
I worked with my vendor support to try to figure this issue out and it really wasn't going anywhere. I ended up switching my workstation to RedHat Enterprise Linux and was able to fully install and run the latest Fluent. It's running now using all 192 available cores.
March 28, 2024, 12:17 |
#7 | |
Omar Zaki
Rep Power: 2 |
May 17, 2024, 13:25 |
Omar Zaki
Rep Power: 2 |
After discussing the issue with Ansys Help Desk, here is what worked for me, using command line:
"C:\Program Files\ANSYS Inc\v241\fluent\ntbin\win64\fluent.exe" 3d -r24.1.0 -mpi=intel2018 -peth -t6 |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
