Fluidized Bed Simulation with Eulerian: Granular only or Granular+Packed Bed?
Old   February 25, 2024, 08:50
Default Fluidized Bed Simulation with Eulerian: Granular only or Granular+Packed Bed?
v
Vivivvvvd is on a distinguished road
hi
During my simulation of a gas-solid fluidized bed using the Eulerian Eulerian method, I found a problem with the pressure drop.
In simulations where the inlet velocity is much less than the minimum fluidization velocity, this pressure drop is consistent with a bubbling state, but there are no bubbles in the Volume Fraction plot of the particles.
I have only selected Granular in the solid setup and not Packed Bed, should I add Packed Bed as an option?
If I should not add the Packed Bed option, what should I do to adjust the parameters of the simulation?
Thank you for your help.
Vivivvvvd is offline   Reply With Quote
fluidized bed, pressure drop
Solution diverges in packed bed granular simulation. Anshs Fluent Multiphase 10 May 12, 2020 10:47
Simulation of fluidized bed dar-2 Fluent Multiphase 7 May 12, 2016 10:23
Fluidized Bed Simulation Siaw Khur CFX 9 July 28, 2010 14:43
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 14:42
granular flow in the packed bed VOG FLUENT 3 June 7, 2007 15:40
