Using UDF to read a table and change heat souce value at every time step.
Old   March 12, 2024, 11:22
Default Using UDF to read a table and change heat souce value at every time step.
Duccio
spidey4 is on a distinguished road
Hi all,
I'm trying to simulate a battery charging cycle, and I want the battery internal volume to be a heat source with the value of qvol changing at every time step, according to the surface temperature.
I have a table with 5 columns:
time
temperature = 20°C
qvol@20°C
temperature = 25°C
qvol@25°C
I can import the table into fluent correctly.
I want to write an UDF that reads the surface temperature of the cell (and takes the average of the whole surface), then approximates it with 20 or 25 and reads the corresponding qvol value and uses it as the qvol of the source term for the next time step.
Is it possible to do so?
spidey4 is offline   Reply With Quote
heat source, table data, transient, udf code
Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model Dingens FLUENT 0 July 9, 2021 06:19
Effect of heat loss ratio dimension on FGM table twb2k8 Main CFD Forum 0 May 15, 2020 13:14
interFoam VOF is loosing fluid wersoe OpenFOAM Running, Solving & CFD 12 June 26, 2013 08:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
