July 12, 2022, 03:30 |
Marangoni shear stress in laser welding
Pourya
DEAR all
I want to simulate the laser welding with the FLUENT. I just activate the solidification and melting (without VOF). I face a problem to import the Marangoni effect into my simulation. In the BOUNDARY CONDITION (MARANGONI STRESS), I found the formula for surface tension gradient variation base on the temperature. Since I could not import the surface tension gradient by UDF in the MARANGONI STRESS, I try to import this effect by UDF in the SPECIFIED SHEAR. I attach the formula for this part and shot screen of specified stress. To be honest, I do not know which Macro I should use to write this formula. I try DEFINE_PROPERTY and DEFINE_PROFILE. In my UDF, I consider the surface tension graidient as a constant. Everytime I run this code, Fluent would close. It is very painful. Please help me to find the error of this UDF. Here you can find the UDF that I wrote for this part. DEFINE_PROFILE(marangonix, t, i) { face_t f; cell_t c; Thread *tc; real grad_temp, gama_temp; begin_f_loop(f,t) { c=F_C0(f,t); tc = THREAD_T0(t); //tc=F_C0_THREAD(f,t); grad_temp= C_T_G(c,tc)[0]; gama_temp=-0.00043; F_PROFILE(f,t,i)=gama_temp*grad_temp; } end_f_loop(f,t) } DEFINE_PROFILE(marangoniy, t, i) { face_t f; cell_t c; Thread *tc; real grad_temp, gama_temp; begin_f_loop(f,t) { c=F_C0(f,t); tc = THREAD_T0(t); //tc=F_C0_THREAD(f,t); grad_temp= C_T_G(c,tc)[1]; gama_temp=-0.00043; F_PROFILE(f,t,i)=gama_temp*grad_temp; } end_f_loop(f,t) } DEFINE_PROFILE(marangoniz, t, i) { face_t f; cell_t c; Thread *tc; real grad_temp, gama_temp; begin_f_loop(f,t) { c=F_C0(f,t); tc = THREAD_T0(t); //tc=F_C0_THREAD(f,t); grad_temp= C_T_G(c,tc)[2]; gama_temp=-0.00043; F_PROFILE(f,t,i)=gama_temp*grad_temp; } end_f_loop(f,t) } I really appreciate, if you help me to solve this issue. Last edited by Pourya.heidari73; July 15, 2022 at 13:06. |
January 18, 2023, 11:30 |
UK
Rep Power: 7 |
Probably best using FLOW-3D WELD for this (https://www.flow3d.com/products/flow3d-weld/) as all the physics are already there and no udfs are needed
March 20, 2024, 23:34 |
Resolved
ankit
I have written the following code for a similar problem (following this thread). These gradients are though cell center temperature gradients and I am working on calculations of face center gradients. There is a trick to get this code work (see end of the post)
#include "udf.h" #include "mem.h" DEFINE_PROFILE(marangonix, t, i) { face_t f; cell_t c; Thread *tc; real grad_temp[ND_ND],gama_tempx; gama_tempx = -0.000199; /*surface tension gradient with temperature for Nb*/ begin_f_loop(f,t) { c = F_C0(f,t); tc = THREAD_T0(t); NV_V(grad_temp, =, C_T_G(c,tc)); if (F_T(f,t) > 2741) { F_PROFILE(f,t,i)=gama_tempx*grad_temp[0]; } else { F_PROFILE(f,t,i)= 0; } } end_f_loop(f,t) } DEFINE_PROFILE(marangoniy, t, i) { face_t f; cell_t c; Thread *tc; real grad_temp[ND_ND], gama_tempy; gama_tempy = -0.000199; /*surface tension gradient with temperature for Nb*/ begin_f_loop(f,t) { c=F_C0(f,t); tc = THREAD_T0(t); NV_V(grad_temp, =, C_T_G(c,tc)); if (F_T(f,t) > 2741) { F_PROFILE(f,t,i)=gama_tempy*grad_temp[1]; } else { F_PROFILE(f,t,i)= 0; } } end_f_loop(f,t) } To run this code:
Shear Stress Calculation in the flow. | auburnuser | FLOW-3D | 11 | May 12, 2018 13:49 |
Cannot achieve negative wall shear stress values in CFD Post (ANSYS) | SAtkins | CFX | 3 | August 3, 2016 14:27 |
How is Marangoni shear stress calculated in FLUENT | princekar | FLUENT | 0 | May 21, 2015 08:06 |
shear stress scalar definitions? | Novak Elliott | CFX | 0 | April 6, 2003 01:45 |
What is the detail definition of wall shear stress | zjm | FLUENT | 0 | January 2, 2002 07:43 |
