March 27, 2024, 06:09 |
Diffusivity in diluite solution
serena
I am trying to model the transport of three drug, in water (carrier fluid). Each drug have a different molecular weight and diffusivity, the Ansys guide suggest to use the constant-dilute-approx or the diluite-approx.
The problem is that in the fist case it set a constant diffusivity for all the mixture component, in the second case instead is necessary to set the diffusivity for each component even for the water(which is the carrier so it doesn't have a diffusivity). I read some posts and someone suggest to use the user-define-scalar but I did't understand hot to properly use it. If you have some suggestion or if you can explain how to set the mixture propriety I wold appreciate it. Thank you! |
May 20, 2024, 22:50 |
louziyi
Hello, my problem is similar to yours, how did you solve it?
diffusivity, diluite solution, diluite-approx, mixture, species transport |
Time-accurate solution restart from steady state solution | jyotir | SU2 | 6 | December 8, 2021 08:34 |
Filtering DNS solutions Vs projecting filtered DNS solution | juliom | Main CFD Forum | 5 | May 19, 2016 16:06 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
