October 6, 2003, 21:39 |
animation sequence files
I am simulating unsteady flow in a batch mode. I could not find the animation sequence file saved though I find the case and data files for each time step saved. To save the data file I used file-data-write command in the script that I am using to run the simulation in a batch mode .
I wonder if I have to add another command or any procedure to follow at the post processing stage inorder the simulation sequence file saved atomatically while fluent runs in batch mode. Infact I follow the procedures to activate animation and it workd fine in the interactive mode the problem I have is to make the corresponding files saved automatically in a batch mode. Thank You |
October 27, 2009, 06:14 |
animation in batch mode
khar nab
Rep Power: 16 |
Hi Solomon,
Did you get an answer conserning this issue? I am encountering the same problem. Regards |
June 7, 2010, 17:18 |
solve/animate/define/define-monitor
Tim Diller
Rep Power: 16 |
I would love to find this out, too. I'm using Fluent12. I can get most of the way there but then get an error.
solve/animate/define/define-monitor after inputing the option for Storage Path Name, I get the following error: Error: No graphics functions are available. Error Object: () Any help? Please? |
June 7, 2010, 17:28 |
Text commands
khar nab
Rep Power: 16 |
Hi all,
I am generating the snapshots using the text commands to set graphics with the appropriate views than save as hardcopy after setting the hardcopy format in the interactive mode. I found that the Fluent text interface is much better that the GUI once we know how to use it Good chance |
June 7, 2010, 17:48 |
#5 | |
Tim Diller
Rep Power: 16 |
Are you using an input file?
Could you possibly post a sample of the commands or script that you would use to generate the images? Quote:
June 7, 2010, 17:57 |
useful commands
khar nab
Rep Power: 16 |
The commands should be something like
disp set-window number disp set contour surface name or number disp contour variable range disp view restore-view view disp view camera up-vector x y z ......... ........... .............. ............... .......... ........... whatever you want as settings then disp hard-copy name of file%-i or f or t.tif Don't forget to set the hardcopy format in the file menu once ghathered you need a software like quicktime pro for example to animate the single files Regards |
April 3, 2024, 12:14 |
Ansys Fluent Post animation after calculation
Joćo Rodrigues
Dear all,
I'm doing some test simulations on Ansys Fluent and after finish calculations I have to make an animation of the result in Post (Results in workbench). This animation sometimes take days and after that is another day to make the animation, between me finding out the simulation already finnished or it ends at middle of the night, there is a time wasted between. Is there a way to make this animation automatically after ending calculations? Via code or file etc Thanks for your attention Best Regards Joćo Rodrigues |
Animation Sequence in Fluent with unsteady state Condition | cycho | FLUENT | 6 | July 26, 2014 06:53 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
