Error: Divergence detected in AMG solver: species-0 |
April 29, 2024, 06:31 |
Evi Partsalidi
Hi i am trying to run a simulation for a pipeline with natural gas that is injected with H2 (vertical pipe).
The simulation runs fine when i am not using udf (so the mesh and setup, initialization etc are okay i guess). As soon as i try to load udfs problems occur. I have one c file that has the 4 equations i need. The first problem occurs when i press build: Error: The UDF library you are trying to load (C:\Users\evipa\Desktop\8\Sim_files\dp0\FFF\Fluent \libudf) is not compiled for 3d on the current platform (win64).\n\nThe system cannot find the file specified. \n\nC:\Users\evipa\Desktop\8\Sim_files\dp0\FFF\Flu ent\C:\Users\evipa\Desktop\8\Sim_files\dp0\FFF\Flu ent\libudf\win64\3d\libudf.dll Error Object: #f (I make sure to delete the previous udf in the library before building again) Despite the message, when i go to manage it shows the udf, so i can load it. Then i put the udf in the materials i use (at the fluid and mixture folder), and do initialization again (haven't changed anything else from the original simutalion that run without udf). Then i keep seeing the same 2 errors over and over again: reversed flow in 5 faces on pressure-outlet 9. # Divergence detected in AMG solver: species-0 -> Increasing relaxation sweeps! # You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t) -------------------------------------------------------------------------------------- Error: Divergence detected in AMG solver: species-0 Error: Divergence detected in AMG solver: species-0 Error Object: #f Any idea on what to do? I keep thinking that the problem is because of the compile but idk how to fix it. Thanks in advance. Yours truly, A desperate student |
April 29, 2024, 14:18 |
Kareem
Rep Power: 3 |
Can you post the UDF you are using?
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
April 30, 2024, 03:08 |
The UDF:
Evi Partsalidi
UDF that simulates solidification by specifying a temperature- dependent viscosity property ************************************************** ********************/ #include "udf.h" #include "global.h" DEFINE_PROPERTY(cell_density,c,t) { real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = (pop+P_op)/100000; real rho; real tr1=289.15; rho = 1/(-1.076443E-03*(tr1/p)+3.989515E-05*(pow(tr1,2)/p)-4.436841E-05*tr1-6.637080E-08*(pow(tr1,3)/p)+3.012561E-08*tr1*p+1.096540E-07*pow(tr1,2)); return rho; } DEFINE_PROPERTY(cell_density_H2,c,t) { real tr1 = 289.15; real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = (pop+P_op)/100000; real rho_H2; rho_H2 = 1/(0.04168135*tr1/p-3.2589E-06*pow(tr1,2)/p+4.2802E-05*tr1+5.9524E-09*pow(tr1,3)/p+6.8998E-09*tr1*p-6.2674E-08*pow(tr1,2)); return rho_H2; } DEFINE_PROPERTY(cell_viscosity,c,t) { real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = (pop+P_op)/100000; real tr1=289.15; real mu; mu = 20.08-20.78*tr1+7.5001*p+9.752*pow(tr1,2)+0.46572*pow(p, 2)-4.7141*tr1*p; return mu; } DEFINE_PROPERTY(cell_viscosity_H2,c,t) { real tr1 = 289.15; real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = (pop+P_op)/100000; real mu_H2; mu_H2= 1.9849+0.0256045*tr1+0.003971*p-0.0000081*pow(tr1,2)+0.000005944*pow(p,2)-0.0000112275*tr1*p; return mu_H2; } DEFINE_PROPERTY(cell_cond,c,t) { real temp = 289.15; real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = pop+P_op; real cond; cond= (0.02003+0.000038*temp+0.000146E-5*p); return cond; } DEFINE_PROPERTY(cell_cond_H2,c,t) { real temp = 289.15; real pop = C_P(c,t); real P_op = RP_Get_Float("operating-pressure"); real p = pop+P_op; real cond_H2; cond_H2= (0.049722+0.000460*temp+0.000074E-5*p); return cond_H2; } |
#ansys, #compile, #fluent, #udf |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
Divergence detected in AMG solver | Rahmani_Zakaria | Fluent Multiphase | 4 | January 11, 2023 15:09 |
Divergence detected in AMG solver: pressure correction | CMICT | FLUENT | 4 | June 14, 2016 12:08 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
