May 20, 2024, 13:53 |
Initialization patch
Alessandro Pinciroli
Hello, I need to simulate a steady state release of hydrogen in a container with an open side opposite to the leak.
The geometry consists of a parallelepiped with a pressure outlet on one of the faces and wall boundary elsewhere. Opposite to the pressure outlet there is a small cylinder with a mass flow inlet of hydrogen, so this is the only inlet of the domain. When I first initialize the solution, I patch the domain in order to have only air inside the container, and I verify it with a contour. As I start the simulation the air concentration drops to 0 and all I see in the domain is hydrogen. Am I doing something wrong with the boundary conditions? I also need an air inlet? Thank you |
initialization, mixture, patch |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
