Periodic BC in Gambit/FLUENT
Old   December 15, 1999, 01:46
Default Periodic BC in Gambit/FLUENT
tom
Hy, 1.) In fluent there is the possibility in the text-interface to make specified boundary-faces periodic. Is it necessary to do this or is it sufficient if you make them periodic in the "normal" boundary-condition-panel ? 2.) is it ok in gambit if I link only the faces (not also the edges) of periodic faces in order to get perodic boundaries ? tom
Old   December 15, 1999, 02:46
Default Re: Periodic BC in Gambit/FLUENT
Jonas Larsson
You have to make them periodic in the text-interface. There is a big "gotcha" there though - before you do this you have to change the rotational axis to the right axis for the fluid domain, otherwise fluent will not be able to match the two meshes. This used to me done automatically, but in the recent versions this feature has dissapeared. You do this from the "boundary conditions" window. If you still have problems to match the two meshes you can try playing a bit with the tolarance - available from the same text-menu. Fluent can be a bit sensitive to small missalignments and sometimes you have to play around a bit to get all nodes matched. If you use linked faces in Gambit it shouldn't be a problem though.
About Gambit, it is enough to link the faces. When you do this Gambit automatically also links the edges around the face.
Old   December 15, 1999, 02:54
Jonas Larsson
A small correction - the "change of axis" of course only applies to rotationally periodic faces.
Old   December 15, 1999, 11:20
Amadou Sowe
I wish Fluent would try to make the implementation of the periodic boundary condition (PBC) less ritualistic. Here is an excerpt of a workaround that was given to me by my support engineer. This was very helpful to me, I hope you find it useful too.
1) In gambit specify the zones as walls rather than use the periodic boundary condition options. For example, I would call one of the zones wall-p and the other wall-p2
2) In fluent5, specify the origin and direction of the axis for all fluid zones.
3) Using the text interface, make the periodic boundries. The make-periodic command is in the grid/modify-zones menu (see example below).
4) Repeat for all periodic zones
5) Grid check will report the rotation/translation data for each pair of periodic zones (see below) so you can check that it is setup correctly.
Old   December 16, 1999, 02:19
tom
Text-interface and bc-pannel are not the same ?
Old   December 16, 1999, 02:40
Jonas Larsson
Nope, the text interface is only available by writing commands in the main fluent window. The boundary condition panel is directly available as a menu that you can open by "clicking on it" with the mouse. The text interface has many hiiden functions in it, functions that Fluent thinks should be used with care and only by the experienced user. I don't know why the "make periodic" function is still there though.
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
