Single Phase Swirling Flow Modelling with Structured and Unstructured Fluent
Old   December 26, 1999, 23:34
Default Single Phase Swirling Flow Modelling with Structured and Unstructured Fluent
Daniel J. Suasnabar
Has someone carried out compartive studies with the structured and unstructured version of Fluent for single phase cyclones, hydrocyclones, or in general swirling flows?. I have done some using the same models and getting grid-independent solution for every version and found big differences. Does anybody know the reason?
Old   December 30, 1999, 16:26
Default Re: Single Phase Swirling Flow Modelling with Structured and Unstructured Fluent
Per Abrahamsen
Be aware that standard k-eps models are not very good at swirling flows . Perhaps the wall functions (if you used them) are defined slightly different in the two versions.
Haven't done the kind of study you are mentioning, though..
Old   January 18, 2000, 02:53
Paal Chr.
We have done some of the same kind of tests and have the same problems. The unstructured code often give somewhat unphysical results, whereas the structured one seems much more reasonable.
We have tested this for k-epsilon, RNG and Reynold stress models, and the same problems occur.
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
structured and unstructured grids user Main CFD Forum 6 November 25, 2010 01:14
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Structured and Unstructured mesh Jingwei FLUENT 0 March 2, 2009 21:29
Unstructured grid problem - Laminar flow pipe Roby FLUENT 0 January 12, 2006 05:54
