Calculating drag coefficient from Fluent
Like Tree9Likes
  • 5 Post By Flav
  • 3 Post By Centurion2011
  • 1 Post By Centurion2011
Old   March 11, 2000, 08:45
Default Calculating drag coefficient from Fluent
Richard
Can any one tell me how to calculate drag coefficient from Fluent on the 2-D airfoil. I have done this using wall force(from fluent display) taking X-direction normalforce + x-direction shear force divide by 0.5u*2 but i end up getting the wrong result. Could any one tell me if this is the right approach.
Old   March 28, 2000, 10:16
Default Re: Calculating drag coefficient from Fluent
Flav
Solve / Monitor / Surface / Drag Then chose the airfoil edges to compute the drag force from.
To get a non-dimensional drag coefficient, set your airfoil parameters in the following section :
Report / Reference values
Set length, speed, rho etc. The reported Cd should be ok now.
Good luck. Cheers, Flav
mr.dargahi, sabin, metmet and 2 others like this.
Old   March 30, 2000, 00:24
N. Jalaiah
Hi Richard,
I also tried to plot the Cd profile for flow past a circular cylider case but the results are not coming correctly. I followed this way.
Solve/Monitors/Force/Drag ... then I chosen the curve for Cd plot.
I set the density, velocity, but not the length at Report / Reference values. I wonder whether length details are truly needed for calculating the Cd value.
Bye, Jalaiah
Old   February 15, 2010, 09:12
alessio
alessios123 is on a distinguished road
Hi guys, i'm tring to calculate the drag force coefficient in a 3-d case and the fluid is behind a cylinder.
the fluid is:
density = 800 kg/m^3
dinamic viscosity = 0.005 kg/ms
velocity = 8 m/s
the cylinder is:
diameter = 13 mm
length = 300 mm
stiffness modulus = 200000 MPa
poisson coefficient = 0.3
to calculate the drag coefficient i push: solve/monitors/force/drag coefficient.....
the direction of the vector of force is in parallel to the flow flowing
i set the reference value:
Area = 0.013*0.3 that is the product for diameter and the length of the cylinder,
Length = 0.013 that is the diameter
then i set other values: viscosity, velocity, density of fluid as i wrote upforward.
i put 90 nodes around the circonference of the cylinder, and 25 along to the length of the cylinder.
the algorytm used is LES, because this is a 3d case
I used PISO
and second order upwind for momentum...
the Cd value is incresing but after 0.02 seconds it is still to 0.7.
How can i do, please help me.
Alessio
Thank to all
alessios123 is offline   Reply With Quote
Old   July 7, 2011, 05:53
Centurion2011's Avatar
Centurion2011 will become famous soon enough
Originally Posted by alessios123 View Post
... I set the reference value:
I used PISO
Alessio
Thank to all
Check the Area one more time, it seem an Area is incorrectly calculated
mr.dargahi, Artur.Ant and daire6 like this.
Centurion2011 is offline   Reply With Quote
Old   August 27, 2011, 20:32
Tobino
tobino is on a distinguished road
I am using Fluent to calculated Force too, my model is a hull of ship. my results showed that the Viscous Force is ok but the Pressure Fore is not corrected. Anybody knows what is wrong?
Tobino,
tobino is offline   Reply With Quote
Old   September 20, 2011, 09:11
Originally Posted by tobino View Post
Tobino,
what do you mean "the Pressure Forcee is not correct?"
daire6 likes this.
Old   March 18, 2014, 01:07
Default Calculating forces
Aalisha
aalisha is on a distinguished road
Hello, I have created a 3-D model of a 3 blade tidal current turbine with the blade length 710 mm and blade width 162 mm. It is surrounded by a cylinder which will act as a rotor and finally by a brick acting as a stator.
After exporting the mesh from gambit 2.2.30 to fluent 6.1, I want to calculate the drag and lift force on the walls of the blades. I have defined the units (angular velocity into rpm), grid interfaces, boundary conditions. However when I follow the command Solve>> Monitors>> Forces
It shows an error saying " No data to plot".
If anyone can explain this?
aalisha is offline   Reply With Quote
Old   February 17, 2015, 07:45
Jakub
Dark_Shepard is on a distinguished road
It just means that you didn't start calculations, so there is nothing to show. After calculations begin, plot should appear.
Dark_Shepard is offline   Reply With Quote
Old   September 21, 2015, 03:24
N B Khan
bestniaz is on a distinguished road
Sir, if we change the reference area value, then we need to run the simulation again???
bestniaz is offline   Reply With Quote
Old   September 21, 2015, 04:44
Default yeap
  #11
It depends on what are you looking for?!
If you are looking for Cd, based on results obtained for aerdynamic force,then these results might not be correct if reference are is not correct.
I'M NOT A GYNECOLOGIST BUT I'LL TAKE A LOOK.
Old   May 3, 2017, 20:08
Default drag breakdown in fluent ???
  #12
Alp ASLAN
albaslan is on a distinguished road
Hi. I am working on Ahmed Body model in CFD. I wanna see drag breakdown values which mean are contributiions to pressure drag from front part (Ck), slant rear end (Cs) and vertical rear end base (Cb). I finished mesh and setup. How can I see these values.
Best regards.
albaslan is offline   Reply With Quote
Old   April 11, 2018, 15:35
Default HOW can calculate drag avreg
  #13
erfan
erfanpournasiri is on a distinguished road
hi evrey body would you tell may how can calculat avreg drag and lift coefitiont in fluent?
tanck you
erfanpournasiri is offline   Reply With Quote
a problem in drag coefficient calculating anijdon OpenFOAM 1 March 20, 2013 12:11
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Reference Area for Calculating Lift and Drag Coefficient of 3D wing mahbub03 Main CFD Forum 3 May 19, 2011 00:21
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
drag coefficient Jean FLUENT 14 November 4, 2002 03:49
