export files
Old   June 27, 2000, 10:14
Default export files
Sebastien DANIEL
Hey all;
I wish to export some output files like temperature or pressure as input file in an other program in Fortran.
With fluent I can export file in .fvc or.fvd but could I export in .f to be readed in a fortran program?
Thank you in advance.
Sebastian Daniel
Old   August 8, 2000, 19:06
Default Re: export files
manuel
hello Sebastian, i am working with Fidap and also with Fortran, you can make "neutral files" on command FI-Post, then all,and finally enter neutral and you will select a parameter and put a name-file, each one with any parameter like velocity, pressure or temperature; then you can read that files in Fortan with command open. i hope this help you. bye
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
