UDF for VOF
Old   July 21, 2000, 10:03
Default UDF for VOF
Pei-Ying Hsieh
I am working on a multi-phase problem. A tube is filled with water at t=0, then, an air bubble flows into the domain at the tube inlet. Due to surface tension, there is a curvature at the air/liquid interface. How to use UDF to specify the air volume fraction at each grid point at the inlet (as a function of time)? Thanks!
Pei-Ying Hsieh
Old   July 17, 2014, 17:38
Default Interface curvature computaion in VOF
Rajesh Singh
rsingh7 is on a distinguished road
I need to calculate force at the interface in VOF simulation. Using CSF model, one need to compute the curvature of the interface. Can any one help me to write fluent UDF for this.
I will really appreciate for this.
Rajesh
rsingh7 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
