Turbulent intensity and turbulent dissipation
Old   September 1, 2000, 06:48
Default Turbulent intensity and turbulent dissipation
Phil
Hello CFD-Users,
I want to know how I can estimate the backflow turbulent kinetic energy. I have already estimated the inflow conditions with some equations I have found in the fluent manual, but I didn't find something for the backflow k and e. Unfortunatly I can't find some values in literature. Any ideas?
Thanks for your help
Phil
Old   September 1, 2000, 07:05
Default Re: Turbulent intensity and turbulent dissipation
Jonas Larsson
As a first shot I'd use the same as what you have on the inlet. If you want to be more accurate you can do the same kind of estimate as you did on the inlets using estimated turbulence levels, length scales and velocities. However, hopefully you will not have any backflow in your final soluation and then it doesn't matter what you set k and epsilon to on the outlets.
Old   February 14, 2018, 05:06
Default backflow turbulent kinetic energy
alialemana is on a distinguished road
I know the thread is quite old but I have the same question. Do I put the same values for k and epsilon I put in for inflow boundary condition (I got them from a DNS).
Thanks a lot!
alialemana is offline   Reply With Quote
k-epsilon: Defining turbulent intensity and length scale? klausb OpenFOAM 0 January 23, 2011 07:28
Turbulent intensity swe704 Main CFD Forum 0 November 13, 2009 03:42
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
turbulent intensity zwdi FLUENT 4 June 24, 2004 04:57
