May 28, 2001, 23:30 |
amg solver
i'm doing multiphase flow in fluidized bed using air and prticle. during iteration i got the problem with AMG solver. i'm not very familiar with it. can anybaody help me ??
May 30, 2001, 11:46 |
Re: amg solver
dont bother about amg solver. the error is from yours, maybe it comes from your setting or your grids. check grid first. the grid cannot be negative volume
regards, |
May 30, 2001, 23:23 |
Re: amg solver
i already check my grid status but there is nothing problem and the volume is not negative. during my iteration, after 2 iteration there is an error. internal error at line 562 in file amgif.c. divergence detected in amg solver. i'm not understand what does it's mean.
May 31, 2001, 09:27 |
Re: amg solver
have you check your problem setting?. tell me about your problem.
May 31, 2001, 09:30 |
Re: amg solver
This message means that you have a divergence problem which is quite frequent in euler multiphase simulation due to high ratio of density between phases.
1. Check out that you have choosen the right velocity/pressure coupling method (body force weight) and try to lower your relaxation factors. 2. Try to converg with first order discretisation schemes first before switching to second order. 3. You can also make transient itération with very small time steps at the begining and try to reach steady state by gradually increasing your time step 4. Check out for turbulent values a few iteration before divergence. If you have non physical values (a high turbulent viscosity ratio for example) converge on laminar solution and use it as initialisation for turbulent flow calculation Best regards Alain |
May 31, 2001, 22:03 |
Re: amg solver
i already ask some one that i can used another multiphase model instead of algebraic slip model.so i no need to used amg solver. is it volume of fluid model more suitable to simulate the fluidized bed column
Fluent IcePak - AMG Solver | Russ | FLUENT | 2 | December 31, 2018 09:57 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Divergence detected in AMG solver: pressure correction | jimmer | FLUENT | 2 | August 7, 2010 06:47 |
reverse flow and divergence in AMG solver | MASOUD | FLUENT | 2 | April 2, 2010 08:48 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
