udf for superheated steam?
Old   October 9, 2001, 18:55
Default udf for superheated steam?
stefan pauly
i want make a transient thermal simulation with steam temperature (380 to 530°C, pressure (5 to 18 MPa) and massflow (10 to 140kg/s ) should be varried. does anybody wrote a udf for material properties of superheated steam and time functions of mass flow or pressure and temperature.
thank you for your answers
Old   October 10, 2001, 04:23
Default Re: udf for superheated steam?
max
I had written a UDF for steam according to IAPWS97,however it was had to vertify.Do you have experiment data for some benchmark?
Old   October 10, 2001, 07:38
stefan pauly
i calculate components (thermal, stress) of great power plants. Experimental data of power plant has not a academic quality. i have two links http://ercoftac.mech.surrey.ac.uk/ and experimental data of air in a pipe for a lot of Re-numbers
http://www.princeton.edu/~gasdyn/ind...superpipe_data can you send me your udf an i check them only in numeric way for my steam data.
Old   February 12, 2014, 05:49
manish
manishkumargond is on a distinguished road
Originally Posted by max
;98568
please give me that udf program for superheated steam
manishkumargond is offline   Reply With Quote
Old   September 17, 2014, 15:17
Default want udf file for the properties of superheated steam
viral nagar
viralnagar5692 is on a distinguished road
I m doing simulation in pipe having cross over pipe....
I want that udf file for superheated steam.....
Can anyone send it to
Viralnagar5692@gmail.com
I hc found from some resources that IAWPS-IF97 code is used....also give me the model information
Thnks in advance
viralnagar5692 is offline   Reply With Quote
Old   September 17, 2014, 15:22
viral nagar
can u srnd it to
I will cross check t same with the numerical data from steam table
Xu & Froment methane steam reforming UDF eeheehee Fluent UDF and Scheme Programming 6 August 27, 2022 01:54
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
