[HELP]mixing plane convergence strategy??
Old   October 23, 2001, 01:22
Default [HELP]mixing plane convergence strategy??
Pak
Hi all users. I have some serious and urgent problem.
The model, i solve now, is below (1) supersonic turbin system consist of 8 converging-diverging nozzle, 80 blade. Over expanded flow in nozzle hits turbine blade.
(2) So, I modeled 1 nozzle and 1 blade with periodic BC's and mixing plane.
(3) BC's are 6.8 Mpa pressure inlet at nozzle inlet, 0.5 Mpa pressure outlet. Rotor speed is 50,000 rpm
(4) I started with 1,000 rpm, mixing plane relaxation factor 0.5, and update interval 1.
(5) But, Reversed flow were not disappeared at mixing plane and Residual showed oscilation after 4000 iteration (about). Before 4000 iter, the Residual shows good convergence.
Is there anyone who had solved turbine problem with fluent like this?, or who has any related articles? reply or mail me plz.
Any comment about solution strategy will help me..
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Force can not converge colopolo CFX 13 October 4, 2011 22:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
