October 23, 2001, 21:47 |
Problem with UDF
Hi, I have developed a code for finding the centroids of each individual cells in a fluid zone.But I run into the error when i try to print out the centroids of the cells, if remove that part from the code the code runs fine.If any body could help me with tis problem would greatly be appreciated. The code runs this way: # include "udf.h" FILE *fout; int id =5;//id of the fluid domain extern Domain *domain; DEFINE_ON_DEMAND(get_coords) {
cell_t c; face_t f; real x[ND_ND]; double vol; int i; Thread *thread = Lookup_Thread(domain,id); fout = fopen("coordinate.out","w"); i=0; fprintf(fout,"thread id %d\n",id); /*if(fout==NULL) { printf("error"); }*/ thread_loop_c(thread,domain) { i = i+1; begin_c_loop(c,thread) { C_CENTROID(x,c,thread); fprintf(fout,"%d %g \n",i,x[0]); i =i+1; } end_c_loop(c,thread) } fclose(fout); } Thanks in advance, Murthy |
October 24, 2001, 10:02 |
Re: Problem with UDF
A simple workaround might be to copy the centroid x,y, and z values into the u,v,w velocity arrays:
thread_loop_c(thread,domain) { begin_c_loop(c,thread) { C_CENTROID(x,c,thread); C_U(c,thread) = x[0]; C_V(c,thread) = x[1]; C_W(c,thread) = x[2]; } end_c_loop(c,thread) } Then just export the "velocity" field. This might not be exactly what you're looking for. Regards, Keith |
October 24, 2001, 14:12 |
Hi, The function runs fine with the C_CENTROID(x,c,thread) part,but when I assign an value of x[0] to another variable, it shows me an error called segmentation violation when this program is run as an compiled/interpreted code.The domain consists of 90 2D quadrilateral cells and Iam able to loop through all the cells.The variable x is defined as real x[2]. Thanks in advance, Murthy
October 24, 2001, 14:53 |
Just to check, are you initializing the flowfield before you run your ON DEMAND function? It may not have any arrays for u and v yet. I usually get seg faults when I try and assign something that has not been initialized yet.
October 24, 2001, 19:08 |
Hi, Thanks for the reply.Apart from the aforesaid I had to include the metric.h header file and sg.h header file to get the results.Once agin thanks for every one who has contributed to my problem. Murthy
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 06:56 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 00:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
UDF problem | chiseung | FLUENT | 4 | January 10, 2002 09:58 |
