Multi Block case.
Old   October 25, 2001, 11:05
Default Multi Block case.
Constantinos Constantinou
Hi There.
I have just started modeling with Gambit pre-processor. I am setting up a problem that inclutes multiblock constrains. That is: I have a Big 3D regtangular volume and in that volume i want to set up smaller volumes.(i.e turbulent flow in a room with furniture). I am able to model air flow in the room on its own but when i add the smaller volumes into it, the smaller volumes are not regognised to be meshed. How can i constrain smaller volumes into biger volumes with gambit?
Can you help me with that please?
Thanks in advance.
Regards
costas
Old   October 26, 2001, 02:00
Default Re: Multi Block case.
Armin Gips
Did you split the volumes? If you need both volumes split them bidirect.
Yours Armin
Suggestions for a multi region conjugate heat transfer problem maddalena OpenFOAM 14 September 4, 2013 18:03
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
bc's of a komegaSST case Zymon OpenFOAM 11 July 25, 2010 09:36
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Multi block geometry Samir FLUENT 0 January 14, 2005 15:55
